10 years agoOutput Linux´s Video to VGA controller in FPGA Fabric through AXI on CV SoC
Hi all, I designed a custom expansion board for the de0 nano SoC with an AD 7123 video DAC and a wolfson audio dac. I have an VGA controller running fine on the FPGA fabric side (driving ...
10 years ago`define DZERO_GREATER 2
`define ADC_CONVST_CYCLES ( 10 - `DZERO_GREATER ) `define WAIT_CYCLES 5 `define TRANSFER_CLOCKS (12) `define SCK_ON ( `ADC_CONVST_CYCLES + `WAIT_CYCLES ) `define SCK_OFF ( `SCK_ON + `TRANSFER_CLOCKS ) `define SHIFT_OFF (`SCK_ON + 6 ) module ltc2308 ( clk,go,ADC_SDO,chansel, ADC_CONVST,ADC_SCK,ADC_SDI,done,data ); input clk,go,ADC_SDO; input [3:0] chansel; output ADC_CONVST,ADC_SCK,done; output reg ADC_SDI; output reg[11:0] data; //////////////////////////////////////////////////////////////////////// //Generates negative reset_p pulse signal at go signal posedge. //////////////////////////////////////////////////////////////////////// wire resetp; reg rstbegin; assign resetp = ( (rstbegin == 1'b0) && (go == 1'b1) )? 1'b0 : 1'b1; always@(posedge clk) begin rstbegin <= go; end //////////////////////////////////////////////////////////////////////// //CFG bits at resetp //////////////////////////////////////////////////////////////////////// reg [5:0] cmd; always@(negedge resetp) begin cmd <= { chansel, 2'b10}; end //////////////////////////////////////////////////////////////////////// //Cycle counter //////////////////////////////////////////////////////////////////////// reg [7:0] counter; assign ADC_CONVST = (counter>`ADC_CONVST_CYCLES)? 1'b0 : 1'b1; always@(posedge clk or negedge resetp) begin if(resetp==1'b0) counter <= 8'b0; else if(done == 1'b0) counter <= counter + 1'b1; end //////////////////////////////////////////////////////////////////////// //SCK //////////////////////////////////////////////////////////////////////// reg sckon; assign ADC_SCK = (sckon==1'b1)? clk : 1'b0; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) sckon <= 1'b0; else if ( (counter>=`SCK_ON && counter<`SCK_OFF) ) sckon <= 1'b1; else sckon <= 1'b0; end //////////////////////////////////////////////////////////////////////// //RX //////////////////////////////////////////////////////////////////////// reg [3:0] irx; assign done = (irx > (`TRANSFER_CLOCKS - 1) )? 1'b1 : 1'b0; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) begin data <= 12'b0; irx <= 4'b0; end else if ( sckon == 1'b1 ) begin irx <= irx + 1'b1; data[11-irx] <= ADC_SDO; end end //////////////////////////////////////////////////////////////////////// //TX //////////////////////////////////////////////////////////////////////// reg [2:0] itx; always@(negedge clk or negedge resetp) begin if(resetp==1'b0) begin itx <= 3'b0; ADC_SDI <= 1'b0; end else if ( (counter >= `SCK_ON) && (counter < `SHIFT_OFF) ) begin itx <= itx + 1'b1; ADC_SDI <= cmd[5-itx]; end else ADC_SDI <= 1'b0; end endmodule what means "time compensated design" ? I use vga because it´s easy to find a cheap "second hand" monitor for use with fpga and almost all people haves one vga monitor ... But i will add hdmi too !! I like qsys so much i enjoy a lot designing my own system i love this architecture, now i have a nios on the fpga side and the system its similar to the I.MX6 soloX with the cortexA + cortex M but with a lot of flexibility, i´m designing a board with the cheaper cyclone V soc i found at mouser 5CSEBA2U19C86N [h=1][/h]
