15 years ago
Output delay constraints
I have center-aligned DDR output interface in my design. Output data is given through ALTDDIO_OUT driven by PLL clock output (0 deg) and the clock output is given by another PLL clock output (90 deg).
I want to set the output delay constraint for the design. I referred "AN433: constraining and analyzing source synchronous outputs".It is given in the paper, page 24,Maximum data invalid constraints that, "The output minimum delay constraint value is the positive skew requirement, and the output maximum delay constraint is the negative skew requirement".
In the altera page, altera.info/support/examples/timequest/exm-tq-ca_ss_out.html, from the example it is understood that the maximum delay is positive and minimum delay is negative value.
Can anyone help me understand the output delay constraints better?
    Yeah, I tried for different values. But, it looks like tool doesn't care for these values and the end results are same (from the timing analyzer).
    One obvious thing that TimeQuest documentation does not tell (possibly for commercial reasons) is this:
    whether delay figures mean tSU or tH or skew or any other expression then at the end of the day the tool does not know or care about how you got it the figures. Nor is the tool ever so precise as to get your figures.
    For outputs, you aim at getting clk to data delay from fpga optimum for external device... thats all
    It is the skew of bus elements (difference of transition times that occur from bit to bit of output data bus).
    You decide an affordable value for the fpga. You will be lucky if you get it or may be you get better than what ask for.
    It is purely fpga parameter. It does not see the external device...
    example 250 ps is commonly used by altera examples.
    What is the skew value represented in the below equation?
    Max = (unit interval / 2) - maximum skew value.
    Min = maximum skew value - (1.5 * unit interval).
    if clock/data trace lengths are equal then you can ignore the board effect. In essence if they are not equal then tSU/tH as seen at fpga pins is modified.
    You must note (minus) tH for min delay.
    The equation is given by altera, see timequest resource centre/examples/centre aligned output delays
    with regard to skew approach as alternative to system approach, I think it kills the whole idea of getting timing right. We must meet the external device timing. It is only good if by coincidence it gets it right !! or if the external device only requires min skew.
    Hi, Thanks for your reply.
    system approach:
    >> max : tsu + max data delay – min clk delay
    >> min : - th + min data delay – max clk delay
    I understand the data delay and clk delay depends on trace length, if the length are same,then Max delay=Tsu, Min Delay=Th?
    skew approach:
    >>however, if device has tsu/th requirement then you must use system approach.
    I think, still we can use skew approach. Any idea of what the below formulae tends to express?
    Skew value is the setup time in max and hold time in min?
    Here is my understanding, hope it doesn't confuse you further:
    system approach:
    Output delay is interpreted as the tSU and -tH of external device as seen at fpga pins. The delay values can be worked out from tSU, tH of output device plus the effect of board delays:
    Max : tSU + max data delay – min clk delay
    Min : - tH + min data delay – max clk delay
    However, in my opinion board delays let alone min/max board delay is theoretical rubbish...Can anybody measure it for sure ?
    skew approach:
    Use this method if device requires min skew or you just want to set your fpga timing irrespective of any device. However, if device has tSU/tH requirement then you must use system approach. It is not an alternative.
    For edge aligned case:
    Max : unit interval – skew
    Min : skew
    For centre aligned case:
