15 years agoOutput delay constraints
Hi, I have center-aligned DDR output interface in my design. Output data is given through ALTDDIO_OUT driven by PLL clock output (0 deg) and the clock output is given by another PLL clock output ...
15 years agoHere is my understanding, hope it doesn't confuse you further:
system approach: Output delay is interpreted as the tSU and -tH of external device as seen at fpga pins. The delay values can be worked out from tSU, tH of output device plus the effect of board delays: Max : tSU + max data delay – min clk delay Min : - tH + min data delay – max clk delay However, in my opinion board delays let alone min/max board delay is theoretical rubbish...Can anybody measure it for sure ? skew approach: Use this method if device requires min skew or you just want to set your fpga timing irrespective of any device. However, if device has tSU/tH requirement then you must use system approach. It is not an alternative. For edge aligned case: Max : unit interval – skew Min : skew For centre aligned case: Max = (unit interval / 2) - maximum skew value. Min = maximum skew value - (1.5 * unit interval).
