16 years agoMaximum Frequency Input on Cyclone 3 device
I have to realise a frequency divisor from 320 MHz to 40 Mhz. I read from datasheet of cyclone 3 that maximum frequency input on clock pin (LVDS in single ended mode) is about 400MHz. Could you confirm it ? I'm not sure about the result for this range of frequency. I would like also to use general purpose pin to do this (TTL), is it possible ? Mb it's better to use arria FPGA for this kind of application? Thanx Remi4 Replies
Ok
Thanks for the reactivity !! Cheers, Remi - Altera_Forum
--- Quote Start --- They classify Max input clock frequency according to "Modes" *1, *2, *4, *7..... What is a Mode ? Is it a kind of protocol for LVDS transmittion ? --- Quote End --- modes is referring to serialization factor. Cyclone III SERDES uses software SERDES only, so you are not limited to the Modes provided by the altlvds MegaFunction. LVDS implies no particular protocol, it's a synchronous raw binary data transmission. - Altera_Forum
Ok,
Thanx for the reply. I'll do test and see the result. In Cyclone 3 device data sheet : .altera.com./literature./hb./cyc3./cyc3_ciii52001.pdf P21 Cyclone III Devices LVDS Receiver Timing Specifications They classify Max input clock frequency according to "Modes" *1, *2, *4, *7..... What is a Mode ? Is it a kind of protocol for LVDS transmittion ? Thx Remi - Altera_Forum
By Cyclone III specification, input toggle rates above 250 MHz are only supported for the LVDS standard. If you want to keep the specification strictly, an external LVDS driver could convert a single ended signal to LVDS. That's obviously more economic than using Arria or similar only to support 320 MHz single ended clock.
In any case, you'll have difficulties to find a driver supporting 320 MHz with a single ended standard. Single ended driven "LVDS", e.g. a low voltage signal from a clock oscillator should most likely work with Cyclone III. If clock quality is critical, you'll get less jitter with an external LVDS repeater or differential output high speed comparator, that's not affected by the interfering signals present in a FPGA.
