sean793
2 months agoMAX10 True LVDS 1.8V Input Characteristics Before and After Configuration
I have a design in which I would like to drive LVDS clock and data from an FPGA part from another manufacturer with a specified supply voltage of 1.5V. This LVDS signal will then be received by an Altera MAX10 device using the true LVDS clock and data inputs. Since the Altera part LVDS inputs are biased at 1.8V, is there any chance that the 1.8V input bias could show up or otherwise be observed at the driving device's output pins before, during, or after the MAX10 configuration?
in unconfigured state, input pins are pulled towards VCCIO through weak pull-up. Current is however low and shouldn't cause problems.
Regards Frank
