sean793
6 months agoMAX10 True LVDS 1.8V Input Characteristics Before and After Configuration
I have a design in which I would like to drive LVDS clock and data from an FPGA part from another manufacturer with a specified supply voltage of 1.5V. This LVDS signal will then be received by an A...
- 6 months ago
in unconfigured state, input pins are pulled towards VCCIO through weak pull-up. Current is however low and shouldn't cause problems.
Regards Frank
AqidAyman_Altera
6 months agoHi,
Refer to the link below on the MAX10 I/O pin behaviour throughout the configuration sequence:
Aqid
- FvM6 months ago
Hi Aqid,
thanks for correcting my previous statement. Other than most Altera FPGA, e.g. Cyclone 10 LP, MAX 10 has IO weak pull-up disabled during first configuration phase. They are turned on in second configuration phase by default, but can stay disabled with respective configuration bit option (ICB settings in programming file generation tool).
Frank
