hemi's avatar
hemi
1 year ago
MAX10 second PLL issue
This is my configuration:
Device MAX10 (10M16DCF256C8G)
Quartus Prime Version 24.1std Build 1077
I need to use a second PLL, but it is not working. I have tried very hard and read the user manual several times. But without success.
Even with fairly relaxed values: 25 MHz inclk, 25 MHz outclk on the first PLL and 75 MHz on the second PLL.
1) Identical clock source: Both PLLs are controlled by the same pin (CLK0p, PIN_L3, can be used for PLL1 and PLL3).
-> Doesn't work. Only one PLL receives a “locked” signal (PLL1).
2) Cascading of PLLs: The first PLL outclk is connected to the second PLL inclk.
-> This does not work either.
3) Different clock sources: One PLL is controlled by PIN_L3 (CLK0p), the other by PIN_K6 (CLK1p). Both have 25 MHz, but different sources.
Unfortunately, I can only use these two pins at the moment.
-> Doesn't work either.
4) Adding CLKCTRL: I have tried adding CLKCTRL in many combinations, but without success.
I am frustrated because it won't work. What am I doing wrong?
Is there a limitation that I haven't recognized yet?
By the way: there is no hint or error message from Quartus.
  • I found the cause.
    That was a good example of rubber duck debugging.
    With the answers from @FvM and @ShengN_Intel in mind, I simplified the design until only the PLLs remained.
    Now I noticed that PLL_3 never worked. And that was strange.
    The cause was quickly found: in the hardware design, we forgot to connect the power supply for PLL_3 (VCCD_PLL3, PIN_D4).
    How annoying! Fortunately, I can switch to PLL_2.
    Thank you very much for your support. It was a great help.
    Helmut
  • hemi's avatar
    hemi
    I found the cause.
    Helmut
  • ShengN_altera's avatar
    ShengN_altera
    Please check this document page 31 https://cdrdv2-public.intel.com/666937/ug_m10_clkpll-683047-666937.pdf
    Two PLLs are cascaded to each other through the clock network. If your design cascades PLLs, the source (upstream) PLL must have a low-bandwidth setting and the destination (downstream) PLL must have a high-bandwidth setting.
    And page 53 for Programmable Bandwidth Parameter Settings.
    Sheng
    • hemi's avatar
      hemi
      Thank you for your prompt reply!
      Yes, I saw that note. But I must admit that I didn't follow it consistently.
      So, I'll try again.
      Helmut
  • FvM's avatar
    FvM
    I had no problems yet to drive multiple PLLs of MAX10, Cyclone 10 LP and earlier FPGA series from a single clock input. Is it a ready-made evalboard or your own design? Can be that you have either an unstable clock source or a noisy PLL power supply.
    Frank
    • hemi's avatar
      hemi
      Thank you for your prompt reply! I am glad to hear that it should work in general.
      I did not have this problem with Cyclone_V. But with MAX10.
      It is our own design, which ran stably when using a PLL.
      However, I will check the quality of the clock. Perhaps there is a problem here that has not been noticed until now.
      Helmut
