MAX10 second PLL issue
- 1 year ago
I found the cause.
That was a good example of rubber duck debugging.
With the answers from @FvM and @ShengN_Intel in mind, I simplified the design until only the PLLs remained.
Now I noticed that PLL_3 never worked. And that was strange.
The cause was quickly found: in the hardware design, we forgot to connect the power supply for PLL_3 (VCCD_PLL3, PIN_D4).
How annoying! Fortunately, I can switch to PLL_2.
Thank you very much for your support. It was a great help.
Helmut
Please check this document page 31 https://cdrdv2-public.intel.com/666937/ug_m10_clkpll-683047-666937.pdf
Two PLLs are cascaded to each other through the clock network. If your design cascades PLLs, the source (upstream) PLL must have a low-bandwidth setting and the destination (downstream) PLL must have a high-bandwidth setting.
And page 53 for Programmable Bandwidth Parameter Settings.
Sheng
- hemi1 year ago
Thank you for your prompt reply!
Yes, I saw that note. But I must admit that I didn't follow it consistently.
So, I'll try again.Regards,
Helmut
