abedin's avatar
abedin
4 months ago
MAX V DEV Board
I wrote a simple VHDL program that gets input from J6.1(p2) pin and output the same voltage at pin J6.2 (M4). I could successfully program the device but as I set the input to 3.3V, I get 0V at the output pin. I am using max v dev board which has 5M570Z CPLD on it. what could be the possible reasons?
  • Hi Abedin,
    I wanted to follow up on this case to check if you have any further questions or concerns. Please feel free to reach out if there's anything you'd like us to assist you with.
    Fakhrul
    • abedin's avatar
      abedin
      library ieee;
      use ieee.std_logic_1164.all;
      entity voltinout is
          port(
              inpinvolt  : in  std_logic;
              outpinvolt : out std_logic
      end entity voltinout;
      architecture Behavior of voltinout is
      begin
              outpinvolt <= inpinvolt;
      end architecture behavior;
      I used pin assignment to specify inpinvolt to J6.1(P2) and outpinvolt to J6.2(M4). My code compiled and in the RTL viewer it shows a direct connection from input to output.
      I used a 3.3V supply and connect it with the input in J6.1 to GND but the output at J6.2 shows zero with a multimeter.
      • FakhrulA_altera's avatar
        FakhrulA_altera
        Hi Abedin,
        Fakhrul
