15 years ago
Last bits of config. bitstream are ignored in Passive Serial Configuration
i am trying to configure Cyclone III (EP3C25E144C8) fpga via Passive Serial configuration method. I send all bitstream data to the fpga, but as you see on the image below, last 9 (or 10) bits of the bitstream are ignored by the fpga and fpga releases Config Done pin, and then releases init done pin. My simple application (blinking a LED) works OK. But why is the fpga ignoring last bits? is this normal?
Thanks..
http://c1109.hizliresim.com/11/9/7/7857.jpg
    --- Quote Start ---
    I don't use a host device. I use a MCU for reading the bitstream from a spi flash memory and programming the fpga.
    --- Quote End ---
    That's exactly what I meant with 'host'
    --- Quote Start ---
    I see that last bits exist in the .rbf file and also in the .hexout file.
    --- Quote End ---
    This is a common practice. Configuration files are generated with pad bits, so that the programming device doesn't need to bother to add them.
    --- Quote Start ---
    Also, on the PS configuration datasheet, it is written that 2 more DCLK pulses are needed after Config Done pin is High to enter Initialization Mode.
    --- Quote End ---
    I don't think those are really needed for CIII. From config_done to user mode (when init_done goes high), the startup sequence is driven by the internal clock, 3185 cycles required.
    --- Quote Start ---
    Those are simply padding bits being transmitted by the host until it receives the CONFIG_DONE signal, or until detects an error condition.
    If you take a look to data line, you see a sequence of 0xFF bytes.
    This is usually done because some devices nuse extra clocks for startup timing
    --- Quote End ---
    I don't use a host device. I use a MCU for reading the bitstream from a spi flash memory and programming the fpga. I see that last bits exist in the .rbf file and also in the .hexout file.
    I will add these 2 more clk pulses but now it seems that is is not needed..
    Do you mean that last FF bytes are dummy bytes for sending blank clock pulses?
    This is usually done because some devices need extra clocks for startup timing.
    The 'substantial' bitstream required for fpga configuration has actually finished a few bytes before you see CONFIG_DONE going high.
    Thanks..
    I remembered that CRC check feature was OFF. I thought that maybe these bits are CheckSum and they are ignored because this feature is OFF. So i switched it ON, then configured the bitstream again.
    But result is the same. As zoomed on the new screen shot below.
    I think that if these bits are CRC bits, then fpga would first check these bits and then decide if there is a CRC error or not. And release the config done pin according to the result.
    Any other ideas?
    http://c1109.hizliresim.com/11/9/7/10429.jpg
    This is a small, test application. It can work. But I am planning to use nearly all logic cells with full performance. So i wonder if those last bits effect the bitstream or not..
    Why bother if it works? It could probably be a checksum or something not very critical. If CRC fails, Your config_done will go low again.
