15 years agoLast bits of config. bitstream are ignored in Passive Serial Configuration
Hello, i am trying to configure Cyclone III (EP3C25E144C8) fpga via Passive Serial configuration method. I send all bitstream data to the fpga, but as you see on the image below, last 9 (or 10) bi...
15 years agoThanks..
I remembered that CRC check feature was OFF. I thought that maybe these bits are CheckSum and they are ignored because this feature is OFF. So i switched it ON, then configured the bitstream again. But result is the same. As zoomed on the new screen shot below. I think that if these bits are CRC bits, then fpga would first check these bits and then decide if there is a CRC error or not. And release the config done pin according to the result. Any other ideas? http://c1109.hizliresim.com/11/9/7/10429.jpg
