15 years agoLast bits of config. bitstream are ignored in Passive Serial Configuration
Hello, i am trying to configure Cyclone III (EP3C25E144C8) fpga via Passive Serial configuration method. I send all bitstream data to the fpga, but as you see on the image below, last 9 (or 10) bi...
15 years agoThis is a small, test application. It can work. But I am planning to use nearly all logic cells with full performance. So i wonder if those last bits effect the bitstream or not..
