incmprehensible error
Hi !!
When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~397" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[1]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~401" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[2]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[3]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~405" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[4]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~409" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[5]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~413" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[6]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|_~417" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[7]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[8]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[9]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[10]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[11]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[12]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[13]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[14]" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]~292" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]~296" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[1]~302" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[1]~307" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[2]~313" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[2]~318" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[3]~324" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[3]~329" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[4]~335" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[4]~340" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[5]~346" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[5]~351" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[6]~357" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[6]~362" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[7]~368" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[7]~373" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[8]~379" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[9]~385" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[10]~391" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[10]~393" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[11]~399" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[12]~403" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[13]~409" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[14]~412" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[3]~422" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]~124bal" of type max_mcell Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]~125bal" of type max_mcell Error: Can't find fit Error: Quartus II Fitter was unsuccessful. 50 errors, 5 warnings Error: Peak virtual memory: 149 megabytes Error: Processing ended: Mon Nov 15 21:38:29 2010 Error: Elapsed time: 00:00:05 Error: Total CPU time (on all processors): 00:00:04 Error: Quartus II Full Compilation was unsuccessful. 52 errors, 14 warnings --- Quote End --- My programm consists to a variable control_2 (std_logic_vector (15 downto 0)) which count up to a constant value . When this value is egal, control_2 is initialized to 0 and count up a new time, etc... The constant can be 4 values defined by the position of a commutator (hardware). Here I don't understand all these errors, and more even if my constant et control_2 is always 16 bits, sometimes i don't have these errors sometimes i have. It depends the value of the constant. An exemple : --- Quote Start --- divide_2 <= "11101010011000000" when choix_frequence = "0001" -- 8Hz else "011000011010100" when choix_frequence = "0010" -- 80Hz else "000010011100010" when choix_frequence = "0100" -- 800Hz else "000000001111101" when choix_frequence = "1000" -- 8000Hz else "000000000000001"; --- Quote End --- Here divide_2 is the constant. The values of divide_2 generate or not the compilation errors. Why if for 8000Hz my value is "000000001101101" I have these errors? And why for this case if my value is "000000001111101" I don't have errors...? The compilation is ok and my outpout is ok. Please Help me...:confused:15 Replies
ok, thank you for your ligth about this subject !!!
--- Quote Start --- That's why I think the compile is made following the value as follows your explanation (josyb) and so the value defines the way of compile. Is correct? --- Quote End --- I think yes because of optimisations. In Quartus messages windows, you can see (a part of) those optimisations. In the report too. I am not an expert, neither a Quartus software designer and I haven't try other compilers. You are focusing on the compiler algorithm, I would advice you to focus more on helping the compiler. Many design tips. @Josyb : thanks for your experience. Nota Bene : On my example above (process(clk_43)) : the last else statement is not needed. - Altera_Forum
josyb => that you mean is quartus doesn't compile with the same way each time when it compiles. That's why sometimes the compilation is ok and after changing a value, the compilation is not ok?
But it's strange, if the first compile is ok and after changing a value the compilation isn't ok, I return my first value and is ok. This work is verified more times. That's why I think the compile is made following the value as follows your explanation (josyb) and so the value defines the way of compile. Is correct? When i find my correct, I'll pray all gods for the compile uses a good way. - Altera_Forum
--- Quote Start --- Thank you mmTsuchi. I apply your code and I don't see the difference. Always the same number of used macrocells than my code. --- Quote End --- If you look in the RTL viewer you see a difference as mmTsuchi mentions, but the fitter does an awfully good job. I once explored alternative ways in determining the leading bit set to one in a std_logic_vector. The two methods I tried produced totally different RTL views, one with a lot of small muxes and the other with only a few but larger muxes. But they produced identical results in the Technology Map Viewer. - Altera_Forum
I guess you use ieee.std_logic_unsigned.all; ? you and others might have a look at http://www.velocityreviews.com/forums/showpost.php?p=142537&postcount=3
Your process(control_2) needs huge resources : 3 comparisons. Synthesis are still "stupid" and you have to "help" their work. I suggest you to employ something likeprocess (clk_43) begin if (clk_43'event and clk_43 ='1') then if control_2 < divide_2 then control_2 <= control_2+"00000000000000001"; elsif control_2 >= divide_2 then -- modified here control_2 <= "00000000000000000"; else control_2 <= control_2; end if; end if; end process;
better is using a process(clk) which avoids glitches of control_2. (It takes only one more D Flip Flop)sortie_11 <= '1' when control_2 <= 3 else '0'; - Altera_Forum
all variables are std_logic or std_logic_vector
My VHDL programm is (for an EPM3064ALC44-10) --- Quote Start --- architecture DESCRIPTION of test_impulsion is signal divide_2 : std_logic_vector (16 downto 0):= "00000000000000000"; signal control_2 : std_logic_vector (16 downto 0):= "00000000000000000"; signal choix_frequence : std_logic_vector (3 downto 0); signal choix_sonde : std_logic_vector (3 downto 0); signal sortie_sonde : std_logic_vector (4 downto 0); begin -- choix_frequence (0) <= entree_40; choix_frequence (1) <= entree_41; choix_frequence (2) <= entree_39; choix_frequence (3) <= entree_37; --:D!! The problem is here, when I change one value, for 80Hz for an example -- the value here is ""00010111011111000"", if I change one bit, maybe the -- compilation is ok or not. Why? The error message is in ma first post:D!! divide_2 <= "11100111100011000" when choix_frequence = "0001" -- 8Hz else "00010111011111000" when choix_frequence = "0010" -- 80Hz else "00000010010011100" when choix_frequence = "0100" -- 800Hz else "00000000001110110" when choix_frequence = "1000" -- 8000Hz else "00000000000000001"; process (clk_43) begin if (clk_43'event and clk_43 ='1') then if control_2 < divide_2 then control_2 <= control_2+"00000000000000001"; elsif control_2 = divide_2 then control_2 <= "00000000000000000"; elsif control_2 > divide_2 then control_2 <= "00000000000000000"; else control_2 <= control_2; end if; end if; end process; process (control_2) begin If (control_2 = 0 or control_2 = 1 or control_2 =2) then sortie_11 <='1'; else sortie_11 <='0'; end if; end process; sortie_28 <= entree_34; sortie_26 <= entree_33; sortie_24 <= entree_31; sortie_27 <= entree_29; choix_sonde(0)<= entree_29; choix_sonde(1) <= entree_31; choix_sonde(2) <= entree_33; choix_sonde(3) <= entree_34; sortie_sonde <= "10010" when choix_sonde = "1000" -- sonde SA70-2 else "10110" when choix_sonde = "0100" -- sonde SBM-2D else "10111" when choix_sonde = "0010" -- sonde SBG else "11001" when choix_sonde = "0001" -- SG-2 else "00000"; sortie_4 <= sortie_sonde(4); sortie_5 <= sortie_sonde(3); sortie_6 <= sortie_sonde(2); sortie_8 <= sortie_sonde(1); sortie_9 <= sortie_sonde(0); end DESCRIPTION; --- Quote End --- To describe the programm : - entree_XX => input of the MAX3064 -output_XX => output of the MAX3064 ==> XX is the pin number. All input and output are std_logic. Hard clock : 1Mhz (quartz) Choix_frequence => this value define the frequency divide_2 => load the counter number control_2 => the counter. When control_2 = divide_2,control_2 begin a new counter since 0. The output is a 3us pulse, so 3 countings of control_2 (when control_2 is 1, 2, and 3 my output is '1', others values output is '0'). edit : total macrocells : 54/64(84%) - Altera_Forum
--- Quote Start --- you may try to use down-counter : which counts from divide_2 downto 0. It is easier to compare a std_logic_vector with 0. The logical comparison is obvious and it needs just some OR gates. --- Quote End --- Not exactly so. What you gain on the swings you loose on the roundabouts. Let's say we have a counter and we have to count X, with X being dynamical. If we count up, we must clear the counter to zero and compare the count to X Clearing is (or can be) cheap, comparing uses a 2-tier of XORs and AND If we count down, we must load the value X into the counter, and compare the count with 0. Loading the counter needs an additional multiplexer at the counter's input, but has a simpler comparison with a single AND. It may be possible that we could make the count loading simpler, but I have to try that out (in my free time?). - Altera_Forum
It is easier to compare a std_logic_vector with 0. The logical comparison is obvious and it needs just some OR gates. - Altera_Forum
Best to post the whole project indeed - it may simply be that the device is full or so. You can't see that from the source code.
BR, Ben
