15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years agojosyb => that you mean is quartus doesn't compile with the same way each time when it compiles. That's why sometimes the compilation is ok and after changing a value, the compilation is not ok?
But it's strange, if the first compile is ok and after changing a value the compilation isn't ok, I return my first value and is ok. This work is verified more times. That's why I think the compile is made following the value as follows your explanation (josyb) and so the value defines the way of compile. Is correct? When i find my correct, I'll pray all gods for the compile uses a good way.
