15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years ago --- Quote Start --- That's why I think the compile is made following the value as follows your explanation (josyb) and so the value defines the way of compile. Is correct? --- Quote End --- I think yes because of optimisations. In Quartus messages windows, you can see (a part of) those optimisations. In the report too. I am not an expert, neither a Quartus software designer and I haven't try other compilers. You are focusing on the compiler algorithm, I would advice you to focus more on helping the compiler. Many design tips. @Josyb : thanks for your experience. Nota Bene : On my example above (process(clk_43)) : the last else statement is not needed.
