15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years agoall variables are std_logic or std_logic_vector
My VHDL programm is (for an EPM3064ALC44-10) --- Quote Start --- architecture DESCRIPTION of test_impulsion is signal divide_2 : std_logic_vector (16 downto 0):= "00000000000000000"; signal control_2 : std_logic_vector (16 downto 0):= "00000000000000000"; signal choix_frequence : std_logic_vector (3 downto 0); signal choix_sonde : std_logic_vector (3 downto 0); signal sortie_sonde : std_logic_vector (4 downto 0); begin -- choix_frequence (0) <= entree_40; choix_frequence (1) <= entree_41; choix_frequence (2) <= entree_39; choix_frequence (3) <= entree_37; --:D!! The problem is here, when I change one value, for 80Hz for an example -- the value here is ""00010111011111000"", if I change one bit, maybe the -- compilation is ok or not. Why? The error message is in ma first post:D!! divide_2 <= "11100111100011000" when choix_frequence = "0001" -- 8Hz else "00010111011111000" when choix_frequence = "0010" -- 80Hz else "00000010010011100" when choix_frequence = "0100" -- 800Hz else "00000000001110110" when choix_frequence = "1000" -- 8000Hz else "00000000000000001"; process (clk_43) begin if (clk_43'event and clk_43 ='1') then if control_2 < divide_2 then control_2 <= control_2+"00000000000000001"; elsif control_2 = divide_2 then control_2 <= "00000000000000000"; elsif control_2 > divide_2 then control_2 <= "00000000000000000"; else control_2 <= control_2; end if; end if; end process; process (control_2) begin If (control_2 = 0 or control_2 = 1 or control_2 =2) then sortie_11 <='1'; else sortie_11 <='0'; end if; end process; sortie_28 <= entree_34; sortie_26 <= entree_33; sortie_24 <= entree_31; sortie_27 <= entree_29; choix_sonde(0)<= entree_29; choix_sonde(1) <= entree_31; choix_sonde(2) <= entree_33; choix_sonde(3) <= entree_34; sortie_sonde <= "10010" when choix_sonde = "1000" -- sonde SA70-2 else "10110" when choix_sonde = "0100" -- sonde SBM-2D else "10111" when choix_sonde = "0010" -- sonde SBG else "11001" when choix_sonde = "0001" -- SG-2 else "00000"; sortie_4 <= sortie_sonde(4); sortie_5 <= sortie_sonde(3); sortie_6 <= sortie_sonde(2); sortie_8 <= sortie_sonde(1); sortie_9 <= sortie_sonde(0); end DESCRIPTION; --- Quote End --- To describe the programm : - entree_XX => input of the MAX3064 -output_XX => output of the MAX3064 ==> XX is the pin number. All input and output are std_logic. Hard clock : 1Mhz (quartz) Choix_frequence => this value define the frequency divide_2 => load the counter number control_2 => the counter. When control_2 = divide_2,control_2 begin a new counter since 0. The output is a 3us pulse, so 3 countings of control_2 (when control_2 is 1, 2, and 3 my output is '1', others values output is '0'). edit : total macrocells : 54/64(84%)
