15 years agoincmprehensible error
Hi !! When i compile my programm, I have these errors : --- Quote Start --- Error: Can't pack LABs Error: Can't place node "lpm_counter:control_2_rtl_0|dffs[0]" of type max_...
15 years agoI guess you use ieee.std_logic_unsigned.all; ? you and others might have a look at http://www.velocityreviews.com/forums/showpost.php?p=142537&postcount=3
process (clk_43)
begin
if (clk_43'event and clk_43 ='1') then
if control_2 < divide_2 then
control_2 <= control_2+"00000000000000001";
elsif control_2 >= divide_2 then -- modified here
control_2 <= "00000000000000000";
else
control_2 <= control_2;
end if;
end if;
end process; Your process(control_2) needs huge resources : 3 comparisons. Synthesis are still "stupid" and you have to "help" their work. I suggest you to employ something like sortie_11 <= '1' when control_2 <= 3 else '0'; better is using a process(clk) which avoids glitches of control_2. (It takes only one more D Flip Flop)
