Seadog's avatar
Seadog
4 years ago
Ignored create_clock warning in C V design
I have a Cyclone V design with a DDR 3 controller. The reference clock for the DDR3 EMIF core is routed directly from a clock pin. The .sdc file for the project has a create_clock command for that reference clock; the .sdc file for the EMIF core also has a create_clock command for the same clock (referenced as pll_ref_clk per the port name on the EMIF top level).
Quartus is giving me the following warning:
Warning (332049): Ignored create_clock at ddr3_v20_p0.sdc(264): Incorrect assignment for clock. Source node: clkinbot_p already has a clock(s) assigned to it. Use the -add option to assign multiple clocks to this node. Clock was not created or updated.
Should I:
  • comment out the create_clock command in the project .sdc file
  • use the -add option (not sure why I would; the clock is routed to only one place)
  • ignore the warning
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
  • Seadog's avatar
    Seadog
    No further info needed, thanks.
    AdzimZM_Altera
    Sorry for the delay in this topic.
    You can either comment out the create_clock command in the project .sdc file or ignore the warning as has been mentioned by sstrell.
    Do you have any further question?
    Adzim
  • Seadog's avatar
    Seadog
    The design is fully constrained, other than the parts I purposely did not constrain (it's on an eval board with a bunch of I/Os not really being used). And certainly the EMIF core is constrained.
  • sstrell's avatar
    sstrell
    You can either ignore the warning or remove your create_clock command since, as you say, the clock is not being used anywhere else in your design. Does the tool still show the design as fully constrained?
