How to use global clock network (Stratix)
in the "Stratix Device Handbook, Volume 1", page 2-74, it is said that "The global clock networks can also be driven by internal logic . . . ". That is exactly what I want to do, but i don't know, how. I have a "generated clock" from the masterclock, by deviding the masterclock by 2. (I know, that I shouldn't do that, and i know, that here are many threads in this forum that are handling this topic, so please concentrate on my main question ;) . . . ) This signal drives a lot of registers in my design. It is working quite well, but I know that it is not nice that this generated clock register has so many fan outs. What I want to do is to feed the output of my clock generating register into a global clock net and all registers that were fed by it now should be fed by this global clock. What I wanted to do is to use a ALTCLKCTRL megafunction, but it is not supported by my Stratix device. But because the device handbook says, that it is possible, I would like to know, how. Thanks, Maik13 Replies
As I am at home now, it's unverified what I am writing, but in the Stratix manual (the one i mentioned in my opening message for this thread) it is said, that I can also use register control lines (such as clock enable) on the global signal lines of the FPGA. Also I can chose "Auto Global Register Control Signals" in the assignment editor. I understand that as exactly the signal I want to put on the global line . . . .
I already tried Signal Tap, but I am not totally satisfied with the results. This might be caused by my unexperience with signal tap. It is very hard to figure out what exactly I can do with signal tap. I promise, I read the whole manual, but I am still full of questions for that tool. . . . . - Altera_Forum
Sorry but we start from very different point of view.
If all is ok, you don't have the problem but you've it. Check it in some way (put a trap in the FPGA to catch your ipotesis), use the signal tap and digital scope to verify that the signal you put in your FPGA are exactly what you expect. Check the result and timing error that Quartus gives to you and fix them. Told that, Altera Global Lines are global CLOCK lines, so your signal must feed clock port of flip flop, not an enable. It's for that reason that Quartus don't put it on a global line, it can't. Good luck - Altera_Forum
I think, the catching of the ADC data is OK because I use the same ADC-data capturing entity in a total different project and I never have any problems there. The ADC data definetely arives correct inside the FPGA . . .
What makes you think, that I probably don't have a problem with my clk_ena, when you have in mind, that there is a time difference between the clk_ena arriving time in my shift register registers of about 5ns. You also have to keep in mind, that this clk_ena signal has a period shift, as it is derived from the main clock (which it should enable). I verified in the simulator (waveform), that I can use the ADC-clock as clk_ena because the period shift can be seen there and everything is all right. BUT that is the shift directly after the toggle flop. Now, this signal is distributed all across the FPGA and on some paths, there is an addition of the above mentioned 5ns. In my oppinion, there could appear an unforseen behaviour. That is the fact because I want to have this signal on the global line. I assume that then, the distribution of the signal is much faster. But as I told you, Quartus does not want to switch my signal to the global line . . . . - Altera_Forum
From what you describe imo the clk_ena is the minor of your problem.
Have you checked the set-up and hold of your data out of the ADC? I think that the problem is when you catch the data, not a problem in the shift register. You need to look the data at the FPGA input with the CLK at the out of the FPGA. FAST INPUT register is an option you can give to Quartus II telling it to use as first flip flop the one placed directly in the pin region. Told that Imo it's better if you reverse the in ENA inside your FPGA in order to have more time to get the data. Best thing ofc is to use the PLL so you can move the time as you want, but maybe you've some reason to not use it. - Altera_Forum
It's almost correct. But I don't use a PLL to divide my master clock. I us a, well . . . , hmmm, yes I know it's bad . . . , I use a "toggle flop" to devide my master clock.
This divided clock is send directly to an FPGA pin which is connected to the ADCs clock and it is directly send to the clock enable of my shift register registers. The registers are clocked by the main clock. "You could register the 19 bit before your shift register if 1 pipe clk don't care."-> I don't understand what you mean by that . . . . and I do not know what the FAST INPUT REGISTER option does. - Altera_Forum
Imo you're looking in the wrong direction.
If you think that you've timing error internal to FPGA you have to look your timing report and analyse the path that are failing. I've never seen problem in clk_ena signal in all my FPGA experiences, all the problems arise from bad synchronisation of the signals. Moreover to acquire correctly your data have you used FAST INPUT REGISTER option? You could register the 19 bit before your shift register if 1 pipe clk don't care. Moreover you should explain better your clock scheme. You've a main clock that is divide by 2 with a PLL and it's output is sent out to the ADC, right? So you're ADC give you 1 sample each ADC_CLK. Moreover with the same PLL you generate an "internal_ADC_CLK" that you use as an enable signal? If yes it's not a very good idea, but it's better and simpler if you acquire the data with the same internal_ADC_CLK and stop. In that way if you've some strange timing problem you can move the data you acquire shifting the ADC_CLK with the use of PLL. But maybe I've understood not good the clock scheme you've. - Altera_Forum
Well, maybe I have a timing problem. But I don't know exactly. That's why I am looking for the improvment of the signal speed at this special signal.
Now, that I know where to look in the Quartus II software, I am pretty sure that I am not able to let this clock enable signal use the global fast signal path. I put this signal into the assignment editor and assigned the assignment name "Auto Global Register Control Signals" to it. After recompiling and looking into the fitter report it is not listed under "Global & Other Fast Signals". It is listed under "Non-Global High Fan-Out Signals" at position 1. This signal I am talking about is used as chip enable in my shift register. The shift register is build out of LUTs and it is very HUUUGE (800 x 19 bits). I build this shift register out of LUTs because there are certain locations in the shift register I read from and write to during the shift process. The shifting is synchronized with the ADC clock via that enable signal I want to be global. (The ADC data is shifted through the shift register. Therefore I use the ADC clock as enable signal.) The ADC clock is derived from the main clock by dividing it by 2. All in all, everything is working very good. However, sometimes i get some strange effect which can be caused by faulty shiftings in the shift register. When I look at the fan outs of my ADC-clock/Shift-register-clock-enable signal, then I see that some shift register registers are reached by the enable signal in less than a ns and some others (which are far away on the FPGA) are reahed after around 5ns. This is a fact I would like to change, so that I can see if my design then will be more stable. Maik - Altera_Forum
Have you timing problem?
Else you don't have to worry about. Moreover you can see if it's in the line that you want from the fitter report under resource section. - Altera_Forum
Okay, but how can I be sure that the signal uses global ruting lines through the device?
It's wrong what you expect.
The fanout will remain the same: fan out is the number of destination of your signal and count the flip flop that your signal has to reach.
