15 years ago
How to get 45Mhz clock out?
Hi dears:
I am using ArriaGX devices, and the board's clock is 100Mhz which is input to the FPGA. And the system need a 45MHz clock, could you have any method to generate this clock through FPGA's PLL?
Otherwise i have to use aonther 45Mhz oscillator.
Thanks!
Jerry
    --- Quote Start ---
    Why not use clken at 45MHz using clock 100MHz as system clock, if it is for inside fpga processing?
    --- Quote End ---
    How do you make a clockenable of 45 MHz starting from a 100 MHz clock? Catch 22?
    --- Quote Start ---
    In fact, I know how to implement PLL using QII. My question is that the ArriaGX's PLL couldn't get a output of 45Mhz when the Pll's input is 100Mhz.
    --- Quote End ---
    I just tried on a blank project and it worked perfectly. Is 45MHz the only output? Because as joysb says if you have other output frequencies it can make it impossible for the pll in some cases.
    If it is for outside fpga you can try 90MHz or 180 ...etc and divide internally then use ddr to pass 45 out
    --- Quote Start ---
    --- Quote End ---
    Basically 100MHz input and 45 MHz does work. But, the LCM (Least Common Multiple) of the input clock and all output clocks must be in the range of the PLL's VCO, e.g. at 100MHz input, and outputs of 45MHz and 80MHz the VCO needs to run at 3.6 GHz, where the allowable range only is 600 to 1400 MHz.
    Hi guys:
    Jerry
    It shouldn't be a problem for the Arria's PLL, with a VCO frequency of 450MHz it should be able to do it.
    use megafunction wizard.
    [tools] -> [megawizard plug-in manager]
    [create a new custom megafunction variation] -> [Next]
    [I/O] -> [ALTPLL]
