15 years agoHow to get 45Mhz clock out?
Hi dears: I am using ArriaGX devices, and the board's clock is 100Mhz which is input to the FPGA. And the system need a 45MHz clock, could you have any method to generate this clock through FPG...
15 years ago --- Quote Start --- In fact, I know how to implement PLL using QII. My question is that the ArriaGX's PLL couldn't get a output of 45Mhz when the Pll's input is 100Mhz. --- Quote End --- I just tried on a blank project and it worked perfectly. Is 45MHz the only output? Because as joysb says if you have other output frequencies it can make it impossible for the pll in some cases.
