15 years agoHow to get 45Mhz clock out?
Hi dears: I am using ArriaGX devices, and the board's clock is 100Mhz which is input to the FPGA. And the system need a 45MHz clock, could you have any method to generate this clock through FPG...
15 years ago --- Quote Start --- Why not use clken at 45MHz using clock 100MHz as system clock, if it is for inside fpga processing? --- Quote End --- How do you make a clockenable of 45 MHz starting from a 100 MHz clock? Catch 22?
