--- Quote Start --- All initial states of variables in Altera FPGA devices after power up are set to 'zero' logic. --- Quote End --- True, if you use the default. You can set them to any value you want using initialization (at least in Verilog, I assume VHDL is similar). Quartus understands that if initialize a register to '1' it will invert the logic sense (since the register will physically initialize to a '0'). So to you it looks like the register initializes to a '1' but it is implemented as active low logic in Quartus (ie, '1' = low level, '0' = high level). I use the following Verilog to generate a long reset pulse at powerup in my Altera FPGA:// PowerUP Reset Logic // generate a 500ms reset pulse on initial powerup `ifdef SIMULATION reg pup_count = 25'd24999900; `else reg pup_count = 25'd0; `endif reg pup_reset = 1'b1; always @(posedge CLOCK_50) begin pup_count <=# TPD pup_count + 1'd1; if (pup_count == 25'd25000000) pup_reset <=# TPD 1'b0; end wire reset = pup_reset; - Altera_Forum
--- Quote Start --- True, if you use the default. You can set them to any value you want using initialization (at least in Verilog, I assume VHDL is similar). I use the following Verilog to generate a long reset pulse at powerup in my Altera FPGA:
--- Quote End --- But there are no other reset instructions in my program only one reset instruction is input reset; reg[10:0] counting; always@(posedge clk or negedge reset) begin if(!reset) counting <= 11'd1; end counting is actually equal to 1 after power on, why?// PowerUP Reset Logic // generate a 500ms reset pulse on initial powerup `ifdef SIMULATION reg pup_count = 25'd24999900; `else reg pup_count = 25'd0; `endif reg pup_reset = 1'b1; always @(posedge CLOCK_50) begin pup_count <=# TPD pup_count + 1'd1; if (pup_count == 25'd25000000) pup_reset <=# TPD 1'b0; end wire reset = pup_reset; - Altera_Forum
The M1 pin is configured as reset pin. This pin is routed to some logic cell in the FPGA which contains a flip-flop/register.
If it is asynchronous reset, it will be routed to the asynchronous reset port of the registers in that logic cell. If synchronous, it will be ANDed with register inputs. Now: When the FPGA powers up, all internal values of all registers, flip-flops, look-up tables, etc are zero. This is the case for the reset signal in that logic cell; thus your logic remains reset until FPGA powers up successfully. In this case the counting signal should be zero at first, and then gets 11'd1. You may not be able to see the 11'd0 value in the SignalTap since FPGA may not be alive at that moments, but you should test it. I'm not sure about this point. After power up, the value which is driven from the reset circuit outside FPGA supplies the reset signal in the FPGA logic cell. Depending on your external value the reset signal inside FPGA may be zero or one. So, at power up your reset signal is zero and then it will be driven by the external value. BUT, the reset signal may fluctuate a number of times before your design becomes stable, so use a reset synchroniser similar to what I posted in order to remove all glitches on the reset signal, both from sources inside FPGA and glitches outside FPGA due to reset circuit (a micro-switch probably). - Altera_Forum
--- Quote Start --- When the FPGA powers up, all internal values of all registers, flip-flops, look-up tables, etc are zero. This is the case for the reset signal in that logic cell; --- Quote End --- An alternative that could be considered would be assigning an inverted logic straight to the I/O. I'm not sure of that, but perhaps the option FAST_OUTPUT_REGISTER is likely to implement that functionality. It is uposed to bypass the register. - Altera_Forum
--- Quote Start --- The M1 pin is configured as reset pin. This pin is routed to some logic cell in the FPGA which contains a flip-flop/register. If it is asynchronous reset, it will be routed to the asynchronous reset port of the registers in that logic cell. If synchronous, it will be ANDed with register inputs. Now: When the FPGA powers up, all internal values of all registers, flip-flops, look-up tables, etc are zero. This is the case for the reset signal in that logic cell; thus your logic remains reset until FPGA powers up successfully. In this case the counting signal should be zero at first, and then gets 11'd1. You may not be able to see the 11'd0 value in the SignalTap since FPGA may not be alive at that moments, but you should test it. I'm not sure about this point. After power up, the value which is driven from the reset circuit outside FPGA supplies the reset signal in the FPGA logic cell. Depending on your external value the reset signal inside FPGA may be zero or one. So, at power up your reset signal is zero and then it will be driven by the external value. BUT, the reset signal may fluctuate a number of times before your design becomes stable, so use a reset synchroniser similar to what I posted in order to remove all glitches on the reset signal, both from sources inside FPGA and glitches outside FPGA due to reset circuit (a micro-switch probably). --- Quote End --- thank you for your reply,there is no reset circuit outside. like you said"In this case the counting signal should be zero at first, and then gets 11'd1." I am a newbie, I'm sorry i don't know what you mean.
