10 years agohow to generate a reset signal in Altera Cyclone Ⅳ series?
Verilog:
input reset;
reg counting;
always@(posedge clk or negedge reset)
begin
if(!reset)
counting <= 11'd0;
end reset signal is connect to “M1” pin. is it counting =...
10 years ago --- Quote Start --- All initial states of variables in Altera FPGA devices after power up are set to 'zero' logic. --- Quote End --- True, if you use the default. You can set them to any value you want using initialization (at least in Verilog, I assume VHDL is similar). Quartus understands that if initialize a register to '1' it will invert the logic sense (since the register will physically initialize to a '0'). So to you it looks like the register initializes to a '1' but it is implemented as active low logic in Quartus (ie, '1' = low level, '0' = high level). I use the following Verilog to generate a long reset pulse at powerup in my Altera FPGA:
// PowerUP Reset Logic
// generate a 500ms reset pulse on initial powerup
`ifdef SIMULATION
reg pup_count = 25'd24999900;
`else
reg pup_count = 25'd0;
`endif
reg pup_reset = 1'b1;
always @(posedge CLOCK_50)
begin
pup_count <=# TPD pup_count + 1'd1;
if (pup_count == 25'd25000000) pup_reset <=# TPD 1'b0;
end
wire reset = pup_reset;
