10 years agohow to generate a reset signal in Altera Cyclone Ⅳ series?
Verilog:
input reset;
reg counting;
always@(posedge clk or negedge reset)
begin
if(!reset)
counting <= 11'd0;
end reset signal is connect to “M1” pin. is it counting =...
10 years ago --- Quote Start --- True, if you use the default. You can set them to any value you want using initialization (at least in Verilog, I assume VHDL is similar). I use the following Verilog to generate a long reset pulse at powerup in my Altera FPGA:
// PowerUP Reset Logic
// generate a 500ms reset pulse on initial powerup
`ifdef SIMULATION
reg pup_count = 25'd24999900;
`else
reg pup_count = 25'd0;
`endif
reg pup_reset = 1'b1;
always @(posedge CLOCK_50)
begin
pup_count <=# TPD pup_count + 1'd1;
if (pup_count == 25'd25000000) pup_reset <=# TPD 1'b0;
end
wire reset = pup_reset; --- Quote End --- But there are no other reset instructions in my program only one reset instruction is input reset; reg[10:0] counting; always@(posedge clk or negedge reset) begin if(!reset) counting <= 11'd1; end counting is actually equal to 1 after power on, why?
