taojinyong's avatar
taojinyong
3 years ago
How to assign some HPS pins from arria10 Soc to FPGA control
Chip: Arria 10AS027E4F29E3SG
Software version: quartus18.1 standard
For some reason I need to give some pins of the HPS to the FPGA to use, I set the pins of the HPS to none in Qsys, and then I use these pins in the fpga, and the compilation reports an error!
The error message is as follows:
Error (14996): The Fitter failed to find a legal placement for all periphery components
Error (14986): After placing as many components as possible, the following errors remain:
Error (175001): The Fitter cannot place 217 pins.
Info (14596): Information about the failing component(s):
Info (175028): The pin name(s): IO_B2A_L18_Y16_P, IO_B2A_L5_AF12_P, IO_B2A_L13_CLK0_AA16_N, IO_B3A_L24_AE5_P, IO_B2A_L13_CLK0_AB16_P and other 212 pins
Info (15647): These pins are in a group of 217 components with similar legality requirements
Error (16234): No legal location could be found out of 165 considered location(s). Reasons why each location could not be used are summarized below:
Error (184016): There were not enough single-ended bidirectional pin locations available (134 locations affected)
Info (175029): H16. Already placed at this location: pin hps_io_hps_io_gpio_gpio1_io23
Info (175015): The I/O pad hps_io_hps_io_gpio_gpio1_io23 is constrained to the location PIN_H16 due to: User Location Constraints (PIN_H16)
Info (14709): The constrained I/O pad is contained within this pin
Info (175029): H17. Already placed at this location: pin hps_io_hps_io_gpio_gpio1_io22
Info (175015): The I/O pad hps_io_hps_io_gpio_gpio1_io22 is constrained to the location PIN_H17 due to: User Location Constraints (PIN_H17)
Info (175029): J19. Already placed at this location: pin hps_io_hps_io_phery_spim0_MOSI
Info (175015): The I/O pad hps_io_hps_io_phery_spim0_MOSI is constrained to the location PIN_J19 due to: User Location Constraints (PIN_J19)
Info (175029): J18. Already placed at this location: pin hps_io_hps_io_phery_spim0_CLK
Info (175015): The I/O pad hps_io_hps_io_phery_spim0_CLK is constrained to the location PIN_J18 due to: User Location Constraints (PIN_J18)
Info (175029): K17. Already placed at this location: pin hps_io_hps_io_phery_spim0_SS0_N
Info (175015): The I/O pad hps_io_hps_io_phery_spim0_SS0_N is constrained to the location PIN_K17 due to: User Location Constraints (PIN_K17)
Info (175029): J17. Already placed at this location: pin hps_io_hps_io_phery_spim0_MISO
Info (175015): The I/O pad hps_io_hps_io_phery_spim0_MISO is constrained to the location PIN_J17 due to: User Location Constraints (PIN_J17)
Info (175029): E21. Already placed at this location: pin hps_io_hps_io_phery_emac0_MDC
Info (175015): The I/O pad hps_io_hps_io_phery_emac0_MDC is constrained to the location PIN_E21 due to: User Location Constraints (PIN_E21)
Info (175029): D22. Already placed at this location: pin hps_io_hps_io_phery_emac0_MDIO
Info (175015): The I/O pad hps_io_hps_io_phery_emac0_MDIO is constrained to the location PIN_D22 due to: User Location Constraints (PIN_D22)
Info (175029): E23. Already placed at this location: pin hps_io_hps_io_gpio_gpio1_io9
Info (175015): The I/O pad hps_io_hps_io_gpio_gpio1_io9 is constrained to the location PIN_E23 due to: User Location Constraints (PIN_E23)
Info (175029): D23. Already placed at this location: pin hps_io_hps_io_gpio_gpio1_io8
Info (175015): The I/O pad hps_io_hps_io_gpio_gpio1_io8 is constrained to the location PIN_D23 due to: User Location Constraints (PIN_D23)
Info (175029): C22. Already placed at this location: pin Flash_OE_N
Info (175015): The I/O pad Flash_OE_N is constrained to the location PIN_C22 due to: User Location Constraints (PIN_C22)
Info (175029): C23. Already placed at this location: pin PWR_INT_VSEL
Info (175015): The I/O pad PWR_INT_VSEL is constrained to the location PIN_C23 due to: User Location Constraints (PIN_C23)
Info (175029): and 122 more locations not displayed
Error (179008): Could not find enough available I/O pin locations that can be configured to use a VCCIO voltage of 1.8V (13 locations affected)
Info (175029): D9
Info (175029): A19
Info (175029): B20
Info (175029): E15
Info (175029): D15
Info (175029): D14
Info (175029): D13
Info (175029): C13
Info (175029): B15
Info (175029): B13
Info (175029): AH13
Info (175029): AG19
Info (175029): and 1 more location not displayed
Error (184016): There were not enough single-ended bidirectional pin locations available (10 locations affected)
Info (175029): A8
Info (175029): A9
Info (175029): AH10
Info (175029): AH11
Info (175029): Y17
Info (175029): AA17
Info (175029): AE21
Info (175029): AF21
Info (175029): AB23
Info (175029): AC23
Error (175005): Could not find a location with: IO_FUNCTION of GPIO (8 locations affected)
Info (175029): F18
Info (175029): F17
Info (175029): H18
Info (175029): G18
Info (175029): G19
Info (175029): G20
Info (175029): F22
Info (175029): E22
  • Hi,
  • Hi,
    If that's the case, you can do a HPS Loan IO;
    goto> Arria 10 HPS IP> Pin Mux and Peripheral Tab >in the Advance FPGA Placement > navigate to I2C and set the "Route to FPGA?" = Yes; any preferred IP Block.
    • taojinyong's avatar
      taojinyong
      Yes, I would like to control the I2C pins F22 and E22 of the HPS through FPGA logic. I first set Q3_7 and Q3_8 of the HPS to none in Qsys and then use the pins F22, E22 in the pin planner. Is this the right way to do it?
