taojinyong
3 years agoHow to assign some HPS pins from arria10 Soc to FPGA control
Chip: Arria 10AS027E4F29E3SG Software version: quartus18.1 standard For some reason I need to give some pins of the HPS to the FPGA to use, I set the pins of the HPS to none in Qsys, and then I ...
EBERLAZARE_I_Intel
3 years agoHi,
You need to verify your pins for your device:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/arria-10/10as027.pdf
Have you done pin assignment before?
- taojinyong3 years ago
Yes, I would like to control the I2C pins F22 and E22 of the HPS through FPGA logic. I first set Q3_7 and Q3_8 of the HPS to none in Qsys and then use the pins F22, E22 in the pin planner. Is this the right way to do it?
