taojinyong
3 years agoHow to assign some HPS pins from arria10 Soc to FPGA control
Chip: Arria 10AS027E4F29E3SG Software version: quartus18.1 standard For some reason I need to give some pins of the HPS to the FPGA to use, I set the pins of the HPS to none in Qsys, and then I ...
EBERLAZARE_I_Intel
3 years agoHi,
If that's the case, you can do a HPS Loan IO;
goto> Arria 10 HPS IP> Pin Mux and Peripheral Tab >in the Advance FPGA Placement > navigate to I2C and set the "Route to FPGA?" = Yes; any preferred IP Block.
