sbj
2 months agoGTS Transceiver PLL Usage
From the GTS Transceiver PHY User Guide: “The GTS System PLL Clocks IP cannot be compiled or simulated as a standalone IP. It must always connect to the GTS PMA/FEC Direct PHY IP.” Does this restr...
sbj
2 months agoHi,
is there a way to find out which refclk should be applied to get a specific output clock on c1.
Usually the IP drop-down menu only shows a specific range.
Is there a way to influence that allowed range by tuning the refclk? If yes, any method/formula we use ?
Ash_R_Altera
1 month agoHi,
Do you have any further comment on the topic?
