14 years ago
FT2232H 245 Synchronous FIFO Mode problem
Hello
Im very new to FPGA's and am still learning so please be kind if the problem is obvious :)
i have a FT2232H set to 245 Synchronous FIFO Mode.
i have a program on the pc using the d2xx drivers sending exactly 512 bytes.
the problem is when the fpga receives these 512 bytes and places them into a ram block module i am using, every time i send the 512 bytes it seams to read in 2 empty bytes first then reads in the correct 512 offsetting every thing by 2 bytes. then the next frame i send every thing is offset by 4 bytes then 6 and so on
my code is very simple
it has 2 buffers that are 3072 bytes (im only using 512 at the moment)
it fills one then once that is full it swaps to the next one and fills that one.
another bit of code is reading the none filling buffer and cycling the data to a dot matrix display (this part of the design is ok and can be ignored)
below is the timing diagram for the 245 FIFI
http://img580.imageshack.us/img580/5303/ft2232htiming.jpg
i have attached my code. all dot matrix display update code can be ignored. the problem lies in the FIFO section.
apart from these extra 2 bytes every frame (causing the buffer to be offset by 2 bytes every frame) it seams to behave correctly.
CLK = 50mhz
fifo_clk = 60mhz from FT2232H
im not sure if its a timing fault or a fault in my state machine.
i have attached my verilog file
any help would be much appreciated or just to be pointed in the right direction :)
its so close to working just this one little problem!
    Thank you very much for your reply.
    I have a bad problem with FT232H which is very similar to FT2232H, but only 1 channel instead of 2.
    I have a data loss every 510 bit (tested on Win7 and Win8.1) and more in other cases.
    In sw I use this code with C# .NET library (v1.0.14.0) to read data
    Pseudocode:
    OpenBySerialNumber("FTXE2X2D");
    SetBitMode(0xFF, FTD2XX_NET.FTDI.FT_BIT_MODES.FT_BIT_MODE_RESET);
    Thread.Sleep(10);
    SetBitMode(0xFF, FTD2XX_NET.FTDI.FT_BIT_MODES.FT_BIT_MODE_SYNC_FIFO);
    Purge(FTD2XX_NET.FTDI.FT_PURGE.FT_PURGE_RX)
    --Cycle
      Read(dataBuffer, 1024, ref numBytesRead);
    --End cycle
    Close();
    *Data loss even with SetFlowControl(FTD2XX_NET.FTDI.FT_FLOW_CONTROL.FT_FLOW_RTS_CTS, 0, 0);
    I have tried to change buffer size (1024 in pseudocode) with other values. If buffer size is 1 no errors, in other case I have a lot of errors (about 0.016% data loss with buffer = 1024 bytes)
    Timing of FT232H are:
    http://imagizer.imageshack.us/v2/xq90/13/7cmg.png
    In VHDL I have this simple code:
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity ft232h_tx is
        port
            FT_CLK    : in std_logic;                            -- 60 MHz FT232H clock
            nTXE        : in std_logic;                            -- Can TX
            nRXF        : in std_logic;                            -- Can RX
            nRD        : out std_logic;                            -- Read
            nSIWU        : out std_logic;                            -- Send Immediate / WakeUp
            nOE        : out std_logic;                            -- Output enable
            nWR        : out std_logic;                            -- FIFO Buffer Write Enable
            ADBUS        : out std_logic_vector(7 downto 0)    -- Bidirectional FIFO data
    end entity;
    architecture rtl of ft232h_tx is
        signal counter : unsigned (7 downto 0) := "00000000";
    begin
        -- don't read
        nOE <= '1';
        nSIWU <= '1';
        nRD <= '1';
        process(FT_CLK, nTXE)
            variable state : std_logic := '0';
        begin
            if (rising_edge(FT_CLK)) then
                if(nTXE = '0') then
                    if(state = '1') then
                        nWR <= '0';
                        -- last data not valid if nTXE goes LOW
                        ADBUS <= std_logic_vector(counter);
                        counter <= counter + 1;
                    end if;
                    state := '1';
                else
                    nWR <= '1';
                    state := '0';
                end if;
            end if;
        end process;
    end rtl;
    That is a simply counter that continuously count up to 255 and so send 0,1,2..,254,255,0,1,2...,254,255 to pc
    and in SDC file I have set these constraints:
    create_clock -name "FT_CLK" -period 16.67ns
    set_input_delay -clock { FT_CLK } -min 9ns nTXE
    set_input_delay -clock { FT_CLK } -max 0ns nTXE
    set_output_delay -max -clock "FT_CLK"  7.500ns }]
    set_output_delay -min -clock "FT_CLK"  0ns }]
    With signaltap I have take this screenshot:
    http://imagizer.imageshack.us/v2/xq90/30/e0pc.png (https://imageshack.com/i/0ue0pcp)
    But I can not find the error.. :(
    Hello
    Its been a while seen i placed with this stuff hehe, I ended up going with a STM32F04 micro instead of the ftdi/fpga
    Here is my code, hopefully if helps you out :)
    I am sending data the opposite direction, from the pc to the fpga.
    .c
    FT_SetBitMode(ftHandle, 0xff, 0);
    Sleep(10);
    FT_SetBitMode(ftHandle, 0xff, 0x40);
    FT_SetLatencyTimer(ftHandle, 16);
    FT_SetUSBParameters(ftHandle,0x10000, 0x10000);
    FT_SetFlowControl(ftHandle, FT_FLOW_RTS_CTS, 0x0, 0x0);
    FT_Purge(ftHandle, FT_PURGE_RX);
    Sleep(10);
    fpga
    // FT2232H Synchronous 245 FIFO
    always @(posedge fifo_clk)
    begin
        case(fifo_state)
            0:  begin // wait for rxf to go low (byte available)
                    if(rxf==0)
                    begin
                        oe=0;
                        fifo_cnt=0;
                        fifo_state=1;
                    end
                end
            1: begin
                    rd = 0;
                    fifo_state=2;
                end
            2: begin
                    // keep reading data untill rxf goes high
                    if(rxf==1)
                    begin
                        rd = 1;
                        oe = 1;
                        fifo_state=0;
                    end else
                    begin
                        // check frame preamble bytes
                        if(preamble_state<3)
                        begin
                            wr_addr = 0;
                            if(preamble==data_in)
                                preamble_state=preamble_state+1;
                            else
                                preamble_state=0;
                        end else
                        if(preamble_state==3)
                        begin
                            // command byte (unused)
                            preamble_state=4;
                        end else
                        begin
                            // frame data bytes
                            wr_addr = wr_addr + 1;
                            // read in 2048 bytes (full frame)
                            if(wr_addr == 2048)
                            begin
                                wr_addr=0;
                                preamble_state = 0;
                                // swap to next buffer
                                buf_ready=!buf_ready;
                            end
                        end
                    end
                end
        endcase
    end
    The fpga side of things a little bit more complex that you might need it as im checking the first three bytes in my packet to keep every thing in sync, if they are wrong it will discard the packet, you can chop this bit of code out if you want. It was for basic error checking and frame sync.
    The above code is just the logic for reading in the bytes from the ftdi, give me a shout if you want the full source. It is sort of mixed in with the full project though hehe.
    So USB data can be corrupted by design by FT232H and we have to implement a CRC check over it?
    Its usually ok but in my project i was streaming video frames at a very high fps and if some thing went wrong (very rare) It would screw up the image alignment, So in my case a needed to put in the simple frame header checking just to make sure I new where I was in case there was a little rare glitch.
    Im sure you will not need this for sending some data from the fpga to the pc occasionally.
    With great FTDI support I have solved problem TXE signal can go HIGH on falling edge of clock and so it must not be checked only on rising edge.
    Working code:
    library ieee;
    entity ft232h_tx is
       port
          nWR      : buffer std_logic;                  -- FIFO Buffer Write Enable
    end entity;
       signal state : std_logic := '0';
    begin
       -- don't read
       nOE <= '1';
       nSIWU <= '1';
       nRD <= '1';
       begin
             if(nTXE = '0') then
                   --nWR <= '0';
                end if;
                state <= '1';
             else
                --nWR <= '1';
                state <= '0';
             end if;
          end if;
       end process;
       nWR <= '1' when nTXE = '1' else
              '0' when (nTXE ='0' and state = '1');
    end rtl;
    Thanks to all
