14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using...
12 years agoHello
Its been a while seen i placed with this stuff hehe, I ended up going with a STM32F04 micro instead of the ftdi/fpga Here is my code, hopefully if helps you out :) I am sending data the opposite direction, from the pc to the fpga. .c
FT_SetBitMode(ftHandle, 0xff, 0);
Sleep(10);
FT_SetBitMode(ftHandle, 0xff, 0x40);
FT_SetLatencyTimer(ftHandle, 16);
FT_SetUSBParameters(ftHandle,0x10000, 0x10000);
FT_SetFlowControl(ftHandle, FT_FLOW_RTS_CTS, 0x0, 0x0);
FT_Purge(ftHandle, FT_PURGE_RX);
Sleep(10);
fpga
// FT2232H Synchronous 245 FIFO
always @(posedge fifo_clk)
begin
case(fifo_state)
0: begin // wait for rxf to go low (byte available)
if(rxf==0)
begin
oe=0;
fifo_cnt=0;
fifo_state=1;
end
end
1: begin
rd = 0;
fifo_state=2;
end
2: begin
// keep reading data untill rxf goes high
if(rxf==1)
begin
rd = 1;
oe = 1;
fifo_state=0;
end else
begin
// check frame preamble bytes
if(preamble_state<3)
begin
wr_addr = 0;
if(preamble==data_in)
preamble_state=preamble_state+1;
else
preamble_state=0;
end else
if(preamble_state==3)
begin
// command byte (unused)
preamble_state=4;
end else
begin
// frame data bytes
wr_addr = wr_addr + 1;
// read in 2048 bytes (full frame)
if(wr_addr == 2048)
begin
wr_addr=0;
preamble_state = 0;
// swap to next buffer
buf_ready=!buf_ready;
end
end
end
end
endcase
end
The fpga side of things a little bit more complex that you might need it as im checking the first three bytes in my packet to keep every thing in sync, if they are wrong it will discard the packet, you can chop this bit of code out if you want. It was for basic error checking and frame sync. The above code is just the logic for reading in the bytes from the ftdi, give me a shout if you want the full source. It is sort of mixed in with the full project though hehe.
