14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using...
12 years agoIts usually ok but in my project i was streaming video frames at a very high fps and if some thing went wrong (very rare) It would screw up the image alignment, So in my case a needed to put in the simple frame header checking just to make sure I new where I was in case there was a little rare glitch.
Im sure you will not need this for sending some data from the fpga to the pc occasionally.
