14 years agoFT2232H 245 Synchronous FIFO Mode problem
Hello Im very new to FPGA's and am still learning so please be kind if the problem is obvious :) i have a FT2232H set to 245 Synchronous FIFO Mode. i have a program on the pc using...
12 years agoWith great FTDI support I have solved problem TXE signal can go HIGH on falling edge of clock and so it must not be checked only on rising edge.
Working code:library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ft232h_tx is
port
FT_CLK : in std_logic; -- 60 MHz FT232H clock
nTXE : in std_logic; -- Can TX
nRXF : in std_logic; -- Can RX
nRD : out std_logic; -- Read
nSIWU : out std_logic; -- Send Immediate / WakeUp
nOE : out std_logic; -- Output enable
nWR : buffer std_logic; -- FIFO Buffer Write Enable
ADBUS : out std_logic_vector(7 downto 0) -- Bidirectional FIFO data
end entity;
architecture rtl of ft232h_tx is
signal counter : unsigned (7 downto 0) := "00000000";
signal state : std_logic := '0';
begin
-- don't read
nOE <= '1';
nSIWU <= '1';
nRD <= '1';
process(FT_CLK, nTXE)
begin
if (rising_edge(FT_CLK)) then
if(nTXE = '0') then
if(state = '1') then
--nWR <= '0';
ADBUS <= std_logic_vector(counter);
counter <= counter + 1;
end if;
state <= '1';
else
--nWR <= '1';
state <= '0';
end if;
end if;
end process;
nWR <= '1' when nTXE = '1' else
'0' when (nTXE ='0' and state = '1');
end rtl; Thanks to all
