FPGA Powering PCB Guidelines??
Could someone provide some PCB design guidelines concerning powering my EP3C16Q240 FPGA? I can only use a 2 layer design, and I need 1.2 V to power the FPGA core and 2.5 V to power all the I/O buffers. Should I use some kind of "voltage bus" for each of the voltage values then connect each pin to those buses and decouple accordingly with capacitors? What if just I connect the voltage pins (of the same value) together, then connect some of them to the corresponding voltage regulator? Would this cause some of those pins to receive reduced voltage and even design failure?
Thanks16 Replies
If you are useing a cyclone III and try to put it on two layers you will have problems. You must follow http://www.altera.com/literature/dp/cyclone3/pcg-01003.pdf I would suggest that you do use 4 or more layers there is little cost difference between that and 2 layers if you use an external company to make the PCB, compared to the cost of the components. Have a look at http://www.pcbtrain.co.uk/ If anyone questions why you have gone to 4 or more layers point out that it is 10X more expensive to fix the radio emssions issues at the enclosure level and 100X to 1000X more expensive to fix the problems in the field. If this is for your function generator, then it will be probably impossiable to get good performance with two layers. - Altera_Forum
so you are manufacturing the pcb own your own, not by a professional service
okay 2 layers are easily self made of course they are cheaper, if you forget shielding and reliability but makes a design over all more expensiv as a multilayer with correct design rules and setup - Altera_Forum
I am "forced" to implement the design in 2 layers only because of our lab equipment. I didn't know there are people who think that 2 layer is better than multilayer :)
This can happen in a company when someone with more "force" than you does not have the updated knowledge about the positiv side of multilayer and the field effects inside a pcb when signal energie is transformed into heat instead of radiated emisions.
i personaly had several discussions in the past and each time it was hard to get the okay from the "force" to give multilayer "a try". luckiely today they all know about it. but maybe it is only a personal used pcb and 2 layer is easier to make at home - Altera_Forum
Who is forceing you to use two layers? Send me a PM and I will suggest ways and reading material to convince the required parties to go to at least 4 layers. - Altera_Forum
Don't forget about the ground pad in the middle of the part.
I see, thank you!
the current that flows into a pin must return somewhere, hopefully a GND pin
the current in combination with the resistant of a track leads to a voltage drop across this track. so you have static currents and dynamic currents due to switching of logic your current is the combination of both now think a bit complex about lots of current peaks of different amplitudes and frequencies so your voltage drop is now always the same and when your traces are to smal, you add inductance (what you should avoid) so the currents comes from your power supply systems and the must return there to close this loop. energie is never lost it is only transformed. in best case into heat and not radiated (EMC) keep the currentflow between power supply and device and back as close as possible imagine a loop antennae with 1 winding and your task is to minimize this area inside this loop. - Altera_Forum
--- Quote Start --- but don't forget the return current on GND for powersupply nets and IOs as well --- Quote End --- What do u mean by that? Can u be more specific please? - Altera_Forum
yes, make those supply traces as WIDE ;) as you can.
