Flash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt:
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00404040: verified No CFI table found at address 0x00200000 Leaving target processor paused Can anyone help me in sorting out this issue? THS! Handsome15 Replies
hi,Maestro,I have a good news to tell u!It works normally now!The real reason is that:the pin-WE is not soldered very well!
Thanks for your kindly help and best regards! - Altera_Forum
I have solder out R8 and R9,Flash_ce is normal,but Flash_oe and Flash_ce is the same result(low voltage is about 1.5V,can't below it).But when i use these pins alone,its low voltage is normal(about 0.4V).I can't fingure out what's the real reason.Is it the reason of CFI core?
Hello handsome, solder out R7 to R9 and try again...
Let's see whether it works... - Altera_Forum
hello,maestro,i found the real problem.when the flash_oe is low level,its voltage is 1.5V,what's the reason?thanks!
handsome - Altera_Forum
Hi handsome, I hope R11 isn't soldered...
You doesn't need to connect pin-13 and pin-15 !!! You wrote (and set address width to 22-bit), I think that isn't a good idea to give your processor a wrong information about your ram. Take a look at the attachment and try it... - Altera_Forum
thanks for your reply,i'll make a try!Hope it will work!
thanks for your reply!i'll make a try!
Take a look at the collateral for the Nios II 2c35 development kit (http://http://www.altera.com/products/devkits/altera/kit-nios-2c35.html), which has a very similar flash.
I think you need to be connecting the BYTE signal and dropping the two least significant address bits. Cheers, - Ura - Altera_Forum
I have set all the time to 200ns,but it also dosen't work!v..........
Hi,Maestor666,your reply is quite in time,thanks!
yes ,i have set base address to 0x00000000,and connected pin byte to vcc(3.3v),and between them i added a r-4.7k. BTW,i set it to work in WORD-mode,so address width is 21-bit(i don't use the pin-13,someone use it,and set address width to 22-bit,but i think this doesn't matter ),data width is 16-bit. pin15(ry/by)is also floated! https://www.alteraforum.com/forum/attachment.php?attachmentid=1316 https://www.alteraforum.com/forum/attachment.php?attachmentid=1317 https://www.alteraforum.com/forum/attachment.php?attachmentid=1318 Handsome
