17 years agoFlash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pau...
17 years agoHi handsome, I hope R11 isn't soldered...
You doesn't need to connect pin-13 and pin-15 !!! You wrote (and set address width to 22-bit), I think that isn't a good idea to give your processor a wrong information about your ram. Take a look at the attachment and try it...
