17 years agoFlash programmer problem-No CFI table found
My board's extend flash is AM29LV320.when i use flash programmer to download the code,it shows the following prompt: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pau...
17 years agoI have solder out R8 and R9,Flash_ce is normal,but Flash_oe and Flash_ce is the same result(low voltage is about 1.5V,can't below it).But when i use these pins alone,its low voltage is normal(about 0.4V).I can't fingure out what's the real reason.Is it the reason of CFI core?
