E-Tile Hard IP for Ethernet pin placement
Hi.
I am trying to build a 100GE Interface for a stratix10 tx device(1st280ey2f55i2lg). I have compiled successfully the example design, but I do not know how to change the location of the e-tile in order to match it to my board. The example design uses :
set_location_assignment PIN_REFCLK_GXER9C_CH1P -to i_clk_ref
set_location_assignment PIN_GXER9C_TX_CH0P -to o_tx_serial[0]
set_location_assignment PIN_GXER9C_TX_CH1P -to o_tx_serial[1]
set_location_assignment PIN_GXER9C_TX_CH2P -to o_tx_serial[2]
set_location_assignment PIN_GXER9C_TX_CH3P -to o_tx_serial[3]
set_location_assignment PIN_GXER9C_RX_CH0P -to i_rx_serial[0]
set_location_assignment PIN_GXER9C_RX_CH1P -to i_rx_serial[1]
set_location_assignment PIN_GXER9C_RX_CH2P -to i_rx_serial[2]
set_location_assignment PIN_GXER9C_RX_CH3P -to i_rx_serial[3]
and when I try to change it to any other tile, I am getting a fitter error. I couldn't find what are the restrictions for the e-tile selection. Please help.
yair shapira
Hi yair,
It was the wrong pin assignment issue. You put 2 different signal in the same pin because you already
set_location_assignment PIN_REFCLK_GXER9C_CH1P -to i_clk_ref. For further information about E-tile hard IP, you may refer to link below https://www.intel.com/content/www/us/en/docs/programmable/683468/21-1/introduction.html
Since your issue has been resolved, I am now close the case. If you happen another issue after the case closed, please do feel free to submit another issue. There will have people reach out to you.
zying
- ZiYing_Intel
Hi yair,
zying
- ZiYing_Intel
Hi yairs,
I have a look and tried your .qar file from my side. It was the pin assignment issue. I made some changes on the pin assignment and it was compiled successfully from my side.
- yairs
Thanks a lot , Now it compiles.
I saw that you made a change in one of the TBI Clocks placement. Could you please elaborate (or refer me to some document) , what is the usage of the TBI Clocks and what are their pin placement rules.
I am going to try to add at least one more 100GE ETILE IP, and probably some 10GE Interfaces in the future.
Thanks for all your help
yair
- yairs
Hi.
I Archived again.
I am attaching the qsf and qpf also separately , just in case...
yair shapira
- ZiYing_Intel
Hi Yairs,
Can you try achieve the project again? because the file that you share to me corrupted and don't have the .qsf and .qpf file inside it.
zying
- yairs
- ZiYing_Intel
Hi yairs,
Can you share the .qar file? So that I can try debug the issue from my side.
zying
- yairs
Sure. Thanks for your help.
I tried (among other options that I do not remember ..) To move to tile 8B channels 0 - 3.
Yair,
- ZiYing_Intel
Hi yair shapira,
May I know that you try change to which tile?
zying
