FPGA resource issue of Cyclone 10 GX devices
Hello Guys,
We used 10CX220F780 before. Now one of our new application will switch to use 10CX105F780. Because both of them are package compatible, we only need to check some special logic physical constrains.
Our question is that their chipplanners show us same pages. However, 105 and 220 should have half difference at least. We checked that they have same x-coordinate and y-coordinate. So they have same counts of LAB resources, why?
Best Regard
- FakhrulA_altera
What you are seeing is expected. The 10CX105F780 and 10CX220F780 use the same F780 package plan, so the Chip Planner can show a very similar floorplan and similar X/Y locations. This is mainly for package compatibility and migration support. Refer: Cyclone 10 GX Package Plan, Cyclone 10 GX Device Overview
However, their usable device resources are different. For example, 10CX105 has about 104K LEs / 38,000 ALMs, while 10CX220 has about 220K LEs / 80,330 ALMs. So even if the Chip Planner view looks similar, the actual available logic capacity is not the same. Check, Cyclone 10 GX Maximum Resources & Cyclone® 10 GX FPGA Product Table
For resource comparison, please refer to the Fitter Resource Usage report or the official device resource tables, instead of only the Chip Planner display. Also, please make sure the correct target device is selected and run a full recompile after changing the device.You may refer to:
Regards.
Fakhrul- MinzhiWang
Hi Fakhrul,
The above messages I can get from datasheet. However, the doubt I have is why they have same LAB numbers? According to the same X/Y locations, I think they have same LAB numbers. Please help to explain about this.
In our application cases, we wanted to constrain some nodes to specified physical LAB locations. So when we switch from 10CX220F780 to 10CX105F780 we are afraid to use those unavailable LAB resources.
As you said, 10CX220 has about 80330 ALM and 10CX105 only has 38000 ALM. So they should have twice difference. We also have 50% chance to touch those unusable LABs?
- FakhrulA_altera
Hi Minzhi,
Although 10CX220F780 and 10CX105F780 are package-compatible and may show a very similar Chip Planner X/Y map, this does not mean they have the same usable LAB resources. The Chip Planner view is mainly the physical coordinate/floorplan representation, while the actual legal resources are determined by the selected device.
Therefore, some fixed LAB locations used on 10CX220F780 may not be available on 10CX105F780, even if the same coordinates are shown.
Recommended next step:
1. Change the target device to 10CX105F780
2. Run a full compilation
3. Review the Fitter messages and post-fit Chip Planner for the constrained nodes
If the assignments are legal, Quartus will accept them. If not, the Fitter will report the unavailable/illegal locations and those constraints should be updated.This should clarify why the same X/Y display does not imply the same LAB count.
Fakhrul
