E-Tile Hard IP for Ethernet pin placement
- 2 years ago
Hi yair,
It was the wrong pin assignment issue. You put 2 different signal in the same pin because you already
set_location_assignment PIN_REFCLK_GXER9C_CH1P -to i_clk_ref. For further information about E-tile hard IP, you may refer to link below https://www.intel.com/content/www/us/en/docs/programmable/683468/21-1/introduction.html
Since your issue has been resolved, I am now close the case. If you happen another issue after the case closed, please do feel free to submit another issue. There will have people reach out to you.
zying
Hi yairs,
I have a look and tried your .qar file from my side. It was the pin assignment issue. I made some changes on the pin assignment and it was compiled successfully from my side.
Thanks a lot , Now it compiles.
I saw that you made a change in one of the TBI Clocks placement. Could you please elaborate (or refer me to some document) , what is the usage of the TBI Clocks and what are their pin placement rules.
I am going to try to add at least one more 100GE ETILE IP, and probably some 10GE Interfaces in the future.
Thanks for all your help
yair
