WLin30's avatar
WLin30
5 years ago
Does the ddr3 descrete components' command & address signals need termination resistors for c10?
I have design a board c5+descrete ddr3 component which command & address signals do not have termination resistors which run ok. I am not sure wheter C10 also ok for such design.
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi WLin30,
    I hope you are doing well.
    I have to close the case since you don't have further question for this case.
    You can always file a new case if you get the problem or issue in using the Intel product.
    Thank you for using Intel Community.
    Adzim
    AdzimZM_Altera
    Hi Sir,
    Do you have any question regarding to this topic?
    Adzim
    AdzimZM_Altera
    Hi Sir,
    You can set your EMIF's parameter according to your memory spec and datasheet.
    For the OCT/ODT, you are encourage to perform on board simulation to get the optimal value.
    As I stated in my previous comment, you can always refer to the Cyclone 10 EMIF User Guide to setup your EMIF's parameter.
    AdzimZM_Altera
    The DDR3 discrete components' command & address signals are required the termination resistor.
    In Cyclone 10, you can use the internal termination scheme such as on-chip termination (OCT) and on-die termination (ODT) instead of external termination resistor.
    You can always refer to Cyclone 10 EMIF User Guide in the link below.
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20116.pdf
    May I know whether you setup the OCT and ODT on your design Cyclone V with DDR3?
    • WLin30's avatar
      WLin30
      Do you mean that by setting Cyclone10's OCT/ODT that need not external termination resistor?
      • WLin30's avatar
        WLin30
        If yes, how to set the EMIF's parameters?
