WLin30
5 years agoDoes the ddr3 descrete components' command & address signals need termination resistors for c10?
I have design a board c5+descrete ddr3 component which command & address signals do not have termination resistors which run ok. I am not sure wheter C10 also ok for such design.
AdzimZM_Altera
5 years agoHi Sir,
You can set your EMIF's parameter according to your memory spec and datasheet.
For the OCT/ODT, you are encourage to perform on board simulation to get the optimal value.
As I stated in my previous comment, you can always refer to the Cyclone 10 EMIF User Guide to setup your EMIF's parameter.
