pladoucr's avatar
pladoucr
2 months ago
Impedance measurement on power lines
We are using precision Multimeters in resistance mode and set them at manual 10K range for checking impedances on all power lines (versus ground) of our products.
We established Ohm ranges for each power line of a product in order to know if the circuit looks ok before applying power.
We have some products that have very sensible parts such as DDR3 memories with 0.75V±0.0375V powers and Altera FPGA with 0.9V±0.03V.
By using another multimeter, we measure around 9V between the unconnected probes of different manufacturers precision multimeters set in such 10K range resistance mode.
Even if the current is extremely small, we are worried that our sensible parts could be affected by this 9V “glitch”.
What does Altera recommend for such measurement ?
We are currently using alternative method like putting a Shunt resistor of 1K between the probes in order to keep the voltage near 0V. Of course all our range are now within 0 to 1K Ohm range and when our probes are unconnected, we always get 1.000K displayed. We can manage working with these low ranges.
thanks
  • Good question — this is a real and underappreciated board-test risk. Let me address it directly.
    Your concern is well-founded. Many precision multimeters in resistance mode apply an open-circuit test voltage that can be significantly higher than the rated operating voltage of sensitive rails. A 9 V open-circuit voltage on a 0.9 V FPGA core rail or a 0.75 V DDR3 Vtt rail is well above the absolute maximum ratings for those supplies, and even a brief transient at that level can cause damage or latent degradation — particularly on fine-geometry FPGA core logic and DDR3 termination circuits.
    Altera's documentation reinforces the sensitivity of these rails. For example:
    • For Agilex 5, the guidance is explicit: to prevent damage, do not drive VSIGP and VSIGN pins until the VCCADC power rail has reached 1.62 V Power Management User Guide Agilex™ 5 FPGAs and SoCs — illustrating how seriously sequencing and voltage thresholds are treated even for analog measurement pins.
    • Power supply noise is a key parameter for sensitive rails such as transceiver voltage rails, directly impacting jitter and bit error rate (BER) AN 721: Creating an FPGA Power Tree — so even sub-damage-level transients on sensitive rails matter.
    Regarding your shunt resistor workaround: your 1 kΩ shunt approach is sound engineering practice and is exactly the right mitigation. By placing a 1 kΩ resistor across the probes, you clamp the open-circuit voltage to a safe level (the multimeter's short-circuit current through 1 kΩ stays in the µA range, producing millivolts rather than volts). The tradeoff — that your measurable range is now 0–1 kΩ — is entirely manageable for board-level power rail impedance checks, where you are looking for gross faults (shorts, opens, missing decoupling) rather than precision impedance values.
    A few additional recommendations consistent with good PDN practice:
    • If the FPGA shares a power rail with another device, reducing PDN parasitic inductance and increasing isolation between the FPGA and any noise source reduces risk — and you must perform a transfer impedance analysis to clearly identify any noise interference risk. Device-Specific Power Delivery Network (PDN) Tool 2.0 User Guide Your multimeter test voltage is effectively an injected noise source on the rail, so the same principle applies.
    • For DDR3 Vtt specifically: when calculating the tolerance for DDR3 Vtt supplies using SSTL15, it is with respect to VCCIO, and you should also take the VCCIO tolerance into the calculation — giving a tight window of approximately ±50 mV across min/max conditions. How do I calculate the tolerance on the Vtt supply for DDR3? A 9 V test stimulus is orders of magnitude outside this window.
    • Some engineers also use a low-voltage LCR meter (set to a 100 mV or 500 mV AC stimulus) for PDN impedance spot-checks — this keeps the stimulus well within safe operating voltage for all rails while still giving meaningful impedance data.
    In summary: continue with your 1 kΩ shunt method. It is a practical, safe, and well-reasoned approach. The alternative of using a meter with a selectable low-voltage test mode (some Keysight/Fluke bench meters allow this) or an LCR meter with a low AC stimulus is also worth considering for production test environments.
  • Farabi_Altera's avatar
    Farabi_Altera
  • pladoucr's avatar
    pladoucr
    Forgot to tell : this is not at the design stage but at production before applying power on our boards.
