Detection of CPLD successfully configured.
Hi All,
I am working on a board with CPLD and three other FPGAs. I am able to configure the CPLD using it's pof file. My question is, is there a way to indicate that the CPLD is configured correctly? I have a pin that is supposed to go high when the configuration is complete. But I do not know how to make this pin go high once the configuration is successful.
Thank you in advance.
In case of custom board, I believe it should have some test points/nodes where you can make use of probes for multi-meter or Oscilloscope.
you can make a use of simple D Flipflop code for checking the status of particular pin of CPLD.
Best Regards
Vikas Jathar
- KURK123
Thank you Vicky.
I have used the multimeter probes and it does show that the pin goes high once the configuration to the CPLD is complete.
I implemented the D-Flipflop code to check. And this convinces me.I wonder why it didn't strike me earlier.
Thank you once again.
- Vicky1
Best Regards
Vikas Jathar
- KURK123
Thank you for your reply.
Yes I have done the pin mapping correctly and configured the CPLD using the .pof file. It is successful too.
I have a custom board and I have not connected the push button/slide switch to the indicator pin. Though it is connected to the LED.
Shall I write some lines of VHDL code to indicate the CPLD_DONE pin should go high once the the configuration is complete?
I don't think so but please let me know if I am missing anything.
Thank you
- Vicky1
I presume that, you have done pin assignment(Assignments->pin planner) for your design & then configured the CPLD using .pof file.
Now try to operate the appropriate slide switch/push button as you have assigned it in pin planner & check the status of appropriate LED for output/result.
Refer the below link for the reference,
https://www.youtube.com/watch?v=VzRLirqt_wI
Best Regards
Vikas Jathar
