Detection of CPLD successfully configured.
- 7 years ago
In case of custom board, I believe it should have some test points/nodes where you can make use of probes for multi-meter or Oscilloscope.
you can make a use of simple D Flipflop code for checking the status of particular pin of CPLD.
Best Regards
Vikas Jathar
I presume that, you have done pin assignment(Assignments->pin planner) for your design & then configured the CPLD using .pof file.
Now try to operate the appropriate slide switch/push button as you have assigned it in pin planner & check the status of appropriate LED for output/result.
Refer the below link for the reference,
https://www.youtube.com/watch?v=VzRLirqt_wI
Best Regards
Vikas Jathar
