KURK123
7 years agoDetection of CPLD successfully configured.
Hi All, I am working on a board with CPLD and three other FPGAs. I am able to configure the CPLD using it's pof file. My question is, is there a way to indicate that the CPLD is configured correct...
- 7 years ago
In case of custom board, I believe it should have some test points/nodes where you can make use of probes for multi-meter or Oscilloscope.
you can make a use of simple D Flipflop code for checking the status of particular pin of CPLD.
Best Regards
Vikas Jathar
KURK123
7 years agoThank you Vicky.
I have used the multimeter probes and it does show that the pin goes high once the configuration to the CPLD is complete.
I implemented the D-Flipflop code to check. And this convinces me.I wonder why it didn't strike me earlier.
Thank you once again.
