Detection of CPLD successfully configured.
- 7 years ago
In case of custom board, I believe it should have some test points/nodes where you can make use of probes for multi-meter or Oscilloscope.
you can make a use of simple D Flipflop code for checking the status of particular pin of CPLD.
Best Regards
Vikas Jathar
Thank you for your reply.
Yes I have done the pin mapping correctly and configured the CPLD using the .pof file. It is successful too.
I have a custom board and I have not connected the push button/slide switch to the indicator pin. Though it is connected to the LED.
Shall I write some lines of VHDL code to indicate the CPLD_DONE pin should go high once the the configuration is complete?
I don't think so but please let me know if I am missing anything.
Thank you
