14 years ago
DDR PIN placement error
Hi all,
I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0
I have this error message when i try to place ddr pins
--- Quote Start ---
Error: altmemphy pin placement was unsuccessful
Error: The assigned location PIN U15 for DQS pin "mem_dqs[0]" is not a legal location
Info: PIN C2 is a legal pin location
Info: PIN C8 is a legal pin location
Error: The assigned location PIN AA5 for DQ pin "mem_dq[0]" is not a legal location
Info: There is no legal DQ location that supports 9 DQ pins
Error: The assigned location PIN AB5 for DQ pin "mem_dq[1]" is not a legal location
Error: The assigned location PIN W6 for DQ pin "mem_dq[2]" is not a legal location
--- Quote End ---
you can find my sdc file (attachment)
Thanks for your help
    Hi Josy,
    --- Quote Start ---
    I'm doing exactly that, as a midnight project though. And I must confess, playing it safe, I stuck to the 'Altera assigned DQS/DQ/DM pins' while developing my PHY. But as I said we swapped a few pins incorrectly and in this project I was going to use the Altera IP (until I got my PHY and Controller tuned) to get the system off the ground. Now my partner-developer is complaining that he has to run a NIOSII Ethernet stack with just the internal memory ...
    My Phy and controller are quite small compared to the Altera IP, and are dedicated to driving a single memory chip ( or at maximum a single rank Dimm) only and is targeted at Cyclone devices. (Although the idea should also work for Stratix devices ...)
    I'll compare a compilation with some non DQS-DQ pins to the compilation with 'correctly assigned' pins.
    --- Quote End ---
    I was planning on taking a crack at writing an IP core for the low-power DDR on the BeMicro-SDK kit. I've written an SDRAM controller before so figured it wouldn't be too impossible (famous last words ...).
    Are you writing your core in Verilog or VHDL? Are you simulating using Modelsim and some Micron memory modules? Any chance you'll share your code, or at least your experiences once you get things working?
    Cheers,
    Dave
    Hi Dave,
    --- Quote Start ---
    --- Quote End ---
    I too progressed via that route. If you keep the controller simple, staying away from the fancy things Altera implements in their HPC II controller, it isn't that complex. And in the end the simple controller outperforms the complex one (time and again).
    --- Quote Start ---
    --- Quote End ---
    It is in VHDL (I try not to touch Veriog -> see http://www.alteraforum.com/forum/showthread.php?t=30879 (http://www.alteraforum.com/forum/showthread.php?t=30879))
    --- Quote Start ---
    --- Quote End ---
    I'm an old-time AHDL hand and I'm hooked on the internal Quartus II simulator and procrastinating on ModelSim , you will tell me I'm wrong, of course :).
    --- Quote Start ---
    --- Quote End ---
    I was contemplating to share it when it was ready (just to show off) but I guess sharing with you would probably get me on the way to ModelSim (even advanced: with models!)
    Josy
    Hi Josy,
    --- Quote Start ---
    --- Quote End ---
    I like simple too :)
    --- Quote Start ---
    It is in VHDL
    --- Quote End ---
    Great!
    --- Quote Start ---
    --- Quote End ---
    I'd be happy to create a Modelsim testbench around it. Hey, I'll even throw in a VHDL based Avalon-MM master bus functional model for good measure.
    Send me an email off-list when your hardware tests show your controller is working, and I'll take it for a spin in the simulator, and see if it'll work with the LPDDR on the BeMicro-SDK. We can post the final version once its working.
    Cheers,
    Dave
    Thank you Dave,
    I return to the main problem THE DDR :s
    I have 2 BANK (3 & 4) exclusively for DDR (2.5v), team hw ask me the placement made by Quartus if i select only the bank 3 and 4.
    result i have only some critical warning...
    --- Quote Start ---
    Warning: Unable to place CK/CKn pair mem_clk and mem_clk_n on a differential pin pair because mem_clk has been assigned to a non-differential pin
    --- Quote End ---
    --- Quote Start ---
    Critical Warning: Memory clock pins mem_clk and mem_clk_n must be placed on DIFFIO p- and n-pins
    --- Quote End ---
    when i chek pin planner:
    mem_clk : Y6
    mem_clk_n : T10
    --- Quote Start ---
    Critical Warning: ALTMEMPHY IP was generated using a speedgrade of 6, but is being compiled for a speedgrade of 8. Timing analysis may not be valid due to violated timing model assumptions.
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    The warnings are telling you what you have done wrong. Consult the pin function tables I posted the link to earlier, and it will tell you what the corresponding differential pair groupings are. The Quartus pin planner device view also shows the pairing.
    The warning about device speed grade probably means that the DDR controller was not created with the 'project default device', just go back and regenerate the core.
    Cheers,
    Dave
    Yes but even when i choose only placement for "mem_clk" in DIFFIO_p T8 and
    "mem_clk_n" in DIFFIO_n T9 (quartus default placement for DQ, DQS, DM...)
    i have the same result
    mem_clk : Y6
    mem_clk_n : T10
    --- Quote Start ---
    mem_clk : Y6
    mem_clk_n : T10
    --- Quote End ---
    It sounds like you did not change the assignments.
    When you are in Pin Planner, double-click on the cell that says PIN_Y6, and edit it to change it to PIN_T8. Then change PIN_T10 to PIN_T9. Click save, and place-and-route your design.
    Cheers,
    Dave
