15 years agoDDR PIN placement error
Hi all, I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0 I have this error message when i try to place ddr pins --- Quote Start --- Error: altmemphy pin placement was...
14 years agoHi Josy,
--- Quote Start --- If you keep the controller simple, staying away from the fancy things Altera implements in their HPC II controller, it isn't that complex. And in the end the simple controller outperforms the complex one (time and again). --- Quote End --- I like simple too :) --- Quote Start --- It is in VHDL --- Quote End --- Great! --- Quote Start --- I'm an old-time AHDL hand and I'm hooked on the internal Quartus II simulator and procrastinating on ModelSim , you will tell me I'm wrong, of course :). I was contemplating to share it when it was ready (just to show off) but I guess sharing with you would probably get me on the way to ModelSim (even advanced: with models!) --- Quote End --- I'd be happy to create a Modelsim testbench around it. Hey, I'll even throw in a VHDL based Avalon-MM master bus functional model for good measure. Send me an email off-list when your hardware tests show your controller is working, and I'll take it for a spin in the simulator, and see if it'll work with the LPDDR on the BeMicro-SDK. We can post the final version once its working. Cheers, Dave
