15 years agoDDR PIN placement error
Hi all, I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0 I have this error message when i try to place ddr pins --- Quote Start --- Error: altmemphy pin placement was...
14 years ago --- Quote Start --- Yes but even when i choose only placement for "mem_clk" in DIFFIO_p T8 and "mem_clk_n" in DIFFIO_n T9 (quartus default placement for DQ, DQS, DM...) i have the same result when i chek pin planner: mem_clk : Y6 mem_clk_n : T10 --- Quote End --- It sounds like you did not change the assignments. When you are in Pin Planner, double-click on the cell that says PIN_Y6, and edit it to change it to PIN_T8. Then change PIN_T10 to PIN_T9. Click save, and place-and-route your design. Cheers, Dave
